Dooie Pop Pop
are these a worthwhile mod for an R?
which aint worth worrying about unless you've got a see through rocker coverFast Guy said:don't think they'll do much apart from look good
Exactlykieron said:which aint worth worrying about unless you've got a see through rocker coverFast Guy said:don't think they'll do much apart from look good
It could do if they weren't set up too well before.Dooie Pop Pop said:wouldn' t making the cam timing more accurate make for a more better smoother revving engine :?
cheers, stu
You can move your torque curve around, you'll get the same improvements regardless of what cams you use.Mr GTiR said:No real benefit when used with standard cams.
who needs cams & pulleys am runing strd 1s & produsing 400ponnies with ease & mor 2 com 8)Dooie Pop Pop said:think im getting this now cheers verniers will allow you to tune each cam individualy if iv read this right. they might not give you masses of extra power but can effect the way its delivered 8)
sound pretty usefull to me
would they be easy to fit with the engine out?
stu
yes, veryDooie Pop Pop said:would they be easy to fit with the engine out?
