Simmo
After reading through a load of threads regarding water injection, ive just about figured out that it is a very good idea when running >1.3b boost. I've heard Aquamist, ERL etc etc.
Can anyone recommend a decent system that is basically automatic, ie it chucks in the water when needed (either on certain boosts or det)?
Where would be a good place to get the recommended system from?
Also does anyone know a decent fitting place around Sussex or Leicestershire that could fit this properly for me?
Kieron: If you read this mate, for your water level sensor on your WI system, how did you build the water level indicator bit?
Cheers, Simmo
Cheers, Simmo
