T
tombola
allo all i have a problem with R
the rad fans will not cut in it will boil over if i leave it runnin
but they do work and relays are fine
the temp sender is dropping to 150 ohms at 80-90 c
is this a right reading deos anyone have the illusive manual for it
with the correct figures .
also does the wiring go from sender to ecu then straight back to relays
or is there more inside the car
since checking sender readouts it will not start when warm but ok
from cold? any ideas ?????????????????? :shock:
