what causes damage in 1 cylinder.
Trip
Car was smoking blue (oil) as seen on this clip
http://s131.photobucket.com/albums/p298/Trip_gtir/?action=view&current=mtahleb001.mp4 @00:19
and on this
http://www.youtube.com/watch?v=N7ZFT_d2cfI @ 09:15
Did a cold compression test and got
60psi, 149psi, 152psi, 150psi
Added a tablespoon of oil in all 4 cylinder and got
100psi, 200+psi, 200+psi, 200+psi
Conclusion
Piston and/or cylinder #1 is damaged.
I had done a compession & leakdown test 3 races ago (around 10min of total racing) and all 4 cylinders where in the 150psi mark. Spark plug on Cylinder 1 has a good and same burnt colour of the other 3. Oil pressure is fine too. AFR (measured from after the turbo) is 11.8 AFR @ WOT. Injectors are all working as i checked using datascan by stopping 1 injector at a time.
Running 1bar of boost and the occasion 1.2bar on a GT2860RS with chipped (Field Access) ECU and 102 octane fuel. Pistons are JE's
What could have caused such damage to #1 and not to the other 3 ?
Thanks
