Yes, when my engine was built I had the entire bottom end balanced (crank, rods with pistons & flywheel).Trondelond said:Would it be beneficial to have the rods balanced or matched in some way?
Yes, as my rods are standard and the car will be at 450hp soon. Currently on 378hp on low boost.Trondelond said:Does that mean you could live happily with a 3071 and standard rods?
I am going to hand in the crank and block for some touchups, so I might as well do the rods as well then. Should save me a little over pauters. ^^Mr GTiR said:Yes, when my engine was built I had the entire bottom end balanced (crank, rods with pistons & flywheel).
