Hi guys, newbie on this board but was over on nissangtir and a couple of other forums a few years ago when i was considering buying a pulsar, just wondering why all the pulsar forums seem kinda dead now? surely they all haven't turned into piles of rust or blown up in last few years?
just going by posts and info it seems this place and others used to be busy at one point then some mass exodus of owners happened and now there's just not a lot of new tuning info out there on pulsars from what i can see which is a bit of a shame
for example as i had been looking at old brake mod thread on here and was going to suggest using a vauxhall meriva disc instead of a clio 172 disc as then you probably wouldnt need to backspace it on the hub with the caliper that was being used in question as it had a slightly better disc offset, think the only mod needed was the centre hole would need reeming out 1mm, it had the 4x100 pcd etc
