Hi there,
I have recently bought a 1992 gti-r and noticed the other day that the horn was not working. I replaced the pin in the steering column that makes contact with the steering wheel, still to no avail.
After closer inspection under the bonnet i have since found that the horn has been replaced, and moved over to one side, and the previous owner has "hotwired" the horn to work temporarily to get it through rego, and then cut the wiring. Unfortunately he has managed to butcher most of the wiring in the car. . . . sigh .
I need to find out what the colouring of the wire and plug is that the horn used to hook up to when it was in the centre behind the grill, and where the horn relay is located to help me trace the wiring to be able to reconnect it properly.
If i am unable to find this out i will have to re-wire the entire horn circuit from scratch.
If anyone can help me out it would be greatly appreciated, please try to be as descriptive as possible with colouring, eg: dark green with a white stripe, as there are heaps of wires.
Thanx.
Kevin. Australia.
Thanx.
Kevin. Australia.
