Braveheart
Can you fit a SAFC with a mapped OE ECU to adjust fueling?
You'll be ok, although its not very efficient. The reason it happens is because of the standard map (values are approx calculated AFR):steve963 said:mine runs rich (less than 10 AFR on full boost) at 1.2 bar on std everything, probably get bore wash though:doh:
Interesting!Micra Ed said:Yes. actually anything external to the ECU would work as it did before, it just should not really be necessary.
I think that was more or less stated on page one :lol:Braveheart said:Maybe I could simplify this by getting the standard ECU mapped, monitor it using a wideband A/F gauge and correct things if need be using SAFC.
Yes it was..... By me. :doh:marcymarc said:I think that was more or less stated on page one :lol:
Braveheart said:Yes it was..... By me. :doh:
I'm going around in circles now. :shock:
Braveheart said:You have to look at the options.... have a couple of beers then look again....:doh: ;-)
Never need an excuse Marc for a beer or two.marcymarc said:Theres only so many times you can look at the options mate, i think its just an excuse to have a couple more beers :lol:
That will be that then..... I'll use the ultimate and put every other option out of my head.Micra Ed said:well for a start then it will be easier for you to get the ultimate done, you can also have a go yourself with guidance. thats not really an option with ecu, I have base maps to get you going.
ashills said:hahaha here we go again u pm'd him bobby to worn him away from ed aswell lol
