P.S. with a secondary ignition amplifier, the OEM ignition transistor just becomes a low power switch.
I can't find a wiring diagram , I'd assume it goes between your existing amp and the coil. Images of it wired in show people using one per plug so I don't know if it goes between your dizzy and the plug as a make shift coil on plug design? Not clear on how that might work.121583188476
This is the ebay link.
It says it's for the 3ohm nology coil.
Would my original transistor be ok before this or would you suggest anything better?
Not seen a honda ignition so I can't comment. I might be coming across as negative, feel free to try anything, it's the only way we learn. I'm just nervous at the lack of specification so again I can't comment.On their page they suggest that it's designed to work on honda ignitions where the coil is built into the distributor and is just one unit before the coil.
Sent from my SM-G920F using Tapatalk
good luckThanks for your help, I'll buy the booster and try it.
Will post up how I get on.
