Tyremonkey
i have no idea im anyway. im goin to say no since its been like that for a while, but been running on standard ecu for a while.
Nope. Worth checking the clearances though; if they're set for the factory cams they may need to be adjusted for the new ones. In terms of fuelling etc the ECU doesn't take any readings (or have any output) to the cams (other than crank angle sensing for the ignition timing) so doesn't need to be remapped... or at least that's how I understood it.thought you would have to remap the car after fitting cams
have you got it on pistonheads?
if im honest, your pictures of the car in the snow would put me off as a buyer.
use the best pictures you have, list all the good points about the car aswell as the spec.
tidy the car up and empty all your stuff out of it.
most of all, keep it simple and to the point
good manWell had enough now its not for sale. Work will soon begin!
