Would that really be the case though Bob as, the gauge is just reacting to changes in air pressure as is the FPR ?!pulsarboby said:it wont affect the boost level but it could bugger your fuel pressure regulator up and cause possible fuel starvation or overfuelling as your drawing the vacuum which works regulator, on your boost vacuum side, if you know what i mean
The volume of the air in the lines isn't actually changing, unless you have a leak. It's the pressure of that air that these two things (boost gauge and FPR) are using. This won't be affected by these two devices using the same vacuum line.
I have my AVC-R plumbed in as specified by Apexi and the pressure sensor is fitted into the FPR vacuum line. I have changed this set up before and as expected, no difference was seen ?!
