Smo
Hey guys,
I've had to attach two Wilwood Calipers together in order to create one (inner half from one and outer half from another). The problem I'm having is the small rubber seal that passes the fluid from one half to the other isn't holding the fluid under pressure, and is leaking when the brake pedal is pressed - does anyone have an idea to stop this happening? I'm assuming torquing the two halves even tighter together is risky considering a thread could strip.
Cheers.
Cheers.
