Mounted them in an appropriate place, got a passenger who knew what det was then went from there!
BANG!!.... That was your det :lol: Only joking ;-)
Joking aside, your knock sensor has been tuned by Nissan to detect engine knock. Watching your knock level and understanding what is normal and what is not is a pretty good place to start (Or to continue for Ollie when his mate is not around).
Abnormal knock is spikey on the trace where the level doubles for an instant. If you see this, reduce your ignition in that area.
I don't know about the Nistune but on the PFC you can tell the ECU to flash the knock warning light above a certain threshold. You can set this threhold lower whilst tuning to see any small warning spikes. If you see them you back off and modify your IGN.
Knock level is not perfect either as differentiating what is normal can sometimes end up with a conservative map.
On our cars I have seen areas when coming on boost and at peak torque can be det limited, peak hp not yet. In the past and in the US where they use lower quality fuels this would have been the case but nowadays with optimax on every corner I think less so.
I believe a RR is the only place to safely and accurately set your peak hp IGN.
To hire a RR for an hour is often less than £100.
Simplistically. Do a run and set a benchmark. Add 2 degs across the high load area and repeat. If peak hp and torque goes up then you know from 5K to 7K you need the increase.
If peak torque stays the same then only keep the increase from 5.5K to 7K.
Add 2 degs to the area that went up and repeat the run. If it stays the same then then go back to your last setting.
Check your knock level whilst doing this for any spikes.
After you've had your hour you can smooth any lumps in the map.
@Steve, TDI North near Warrington are GTIROC friendly.
I say simplistically because if you are self mapping then before you go near a RR you need to know your fuelling and knock are all good. Before you start you need to check your base timing is the same in the ECU as on your engine with a timing light. To maximse your time, you need to be profficient at modifying your map on the fly whilst people are watching you.
If you are not sure then that's where people like Ed help out.
