the filter im using is a biltzantgtir said:Jimmy what problem are you getting, crap idle?
I put a filter on mine a while back, M's K+N, and it idled ok but when you put your foot on the throttle it spluttered like buggery. Never found out what it could be but as soon as i took it off and replaced the original filter it ran great again :? So if its somethin like this youve got then i would replace the original filter setup and see what the effects of that are, you can narrow your search down considerably id say.
Ant.
yes there, it just isn't very interestingMarkTurbo said:theres nothing inside it to look at
So i take it the Pipercross filter was working fine?JIMMYBACK B said:the filter im using is a biltzantgtir said:Jimmy what problem are you getting, crap idle?
Ant.i was using a piper cross before.but i gave that to my mate :shock: so wot to do now :?:
	i just wanted to know if i have knocked something inside the afm n maybe thats causing the idle problem :shock: so if i have a reference to wot it should look like i can tell if i have fucked itMarkTurbo said:What do you need a pic of the inside of it for, theres nothing inside it to look at
As long as it isnt full of crap it should be ok.
cheers bud i will try that............god damn i love maplins they have saved me a packetjiw said:Try isopropyl alcohol from www.maplin.co.uk , cut the bottom of a 5 litre antifreeze bottle up to sit the maf in and let it bathe in their for a couple of days, thats what i did anyway, jeff
